1 - 7 of 7 Posts
My lower tailgate is stuck shut. latch does not seem to be working. does anyone know how I can get it open to fix the problem?
Handle is probably broken, remove the inside cover, pull the two rods running from the handle to the latches towards the center.
Then buy an aluminum one from stg249
Discussion Starter · #4 ·
thanks for the response and that sounds good, but I cant get at the inside cover. bloody thing wont open up. when I looked at the side of the box I seen there was a bolt on each side. do u know if that is for the pins that it looks on? if so I could undo the bolts and it should drop open that way. ?
If you take the top tail gate off remove the divider you may have to pry it out from the front of the divider then remove the screws from the inside cover of the lower tail gate that will give you access to all the latches inside so u can open it once you get that over off. It may just need some lubrication on the mechanismas.
Bump to the top for anyone wondering. This just helped me!
1 - 7 of 7 Posts
