Lower ball joint
1 reading
10K views 16 replies 5 participants last post by  takethetime
#1 ·
Does anyone know what the lower ball joint bolt torques at? I dont wanna over torque it that seems to be where the spindles are breaking. I looked in the service manual and cant find it.
#9 ·
These values should be checked as I am thinking they are wrong.
Cannot find the correct values in the manual!
#7 ·
Thanks I'm putting the QE in tomorrow trying to get everything together before I start. I have a new rack with tie rods for sale if anyone needs it.
#10 · (Edited)
I am having a hell of a time finding the correct torque values for upper and lower ball joint and lower and upper a arm bolts.
I cannot find them in the electronic manual I have and I do not believe the values above as they were in the steering section and related to the steering column I believe,
HELP Please !
#11 ·
I cannot find them in the electronic manual I have and ai do not belie the values above as they were in the steering section and related to the steering column I believe,
HELP Please !
I have the shop manual and I can't find them either found the shock bolts etc etc but nothing on the ball joints only how to remove them I'm looking in the book from brp. STRANGE.
#17 ·
Went to the dealer today, they informed me that their book was likely more complete then theirs but when we looked it was no different actually. We did not find a table like appears in the rest of the manual for tourques but there was a parts explosion that listed one value for the upper A-arm bolt which is 35 ft/lbs. because the rest of the bolts were the same size I went 35 on everything.
Note for everyone, starting to notice that their are random parts that you would think were metric but are not. Had a couple other instance with Torx screws. On the upper A-arm, the long bolt that holds it on, the head is
5/8 ths and the nut is metric 15 or 17 mm, go figure!
