1 - 4 of 4 Posts
Hey guys, I have the 2" RT lift, plus 2" extended trailing arms. I threw on some axles stenders and did a test drive (on pavement, around the neighborhood). It performed fine. However, I'm worried when I take her off-road and articulate a bit they may pop out and tear up the axles. Attached pics from both side of the diff. So far, best suggestion for axle replacement is OEM Maverick XC/XXC axles as they are about 1/2" longer. Any other suggestions for decent aftermarket axles that are at least 1/2" longer? I don't need top of the line or the most hardcore option...just OEM or better strength and a bit longer. As of now, I'll most likely stick with the Maverick axle option. Thanks in advance guys.
65985
65986
I put the RT 2” lift in a 2013 mander limited with zero issues. What machine are you running?
Hey guys, I have the 2" RT lift, plus 2" extended trailing arms. I threw on some axles stenders and did a test drive (on pavement, around the neighborhood). It performed fine. However, I'm worried when I take her off-road and articulate a bit they may pop out and tear up the axles. Attached pics from both side of the diff. So far, best suggestion for axle replacement is OEM Maverick XC/XXC axles as they are about 1/2" longer. Any other suggestions for decent aftermarket axles that are at least 1/2" longer? I don't need top of the line or the most hardcore option...just OEM or better strength and a bit longer. As of now, I'll most likely stick with the Maverick axle option. Thanks in advance guys. View attachment 65985 View attachment 65986
I have the RT lift PLUS the 2" extended trailing arms...doesnt equate to a full 4"...but close enough. Just the lift it was fine, with the arms, they pull out. I ordered Maverick XXC OEM axles today, and I will be selling my OEM axles, as theyre basically brand new (100 miles or so)
Thanks!
Sorry for the late reply but yes oem Mav xxc axles are the way to go
1 - 4 of 4 Posts
