When I first start up the engine light comes on and limp mode scrolls across. After about 20-30 seconds it goes away and runs fine. It never did this during hunting season in the fall and just started doing this. I replaced the oil pressure switch/sensor thinking that was the problem but still did it at start up. Any ideas on what to check next ? Oil level is fine
If you turn key on and don't start engine does it show limp mode or only after you start it? If it's on when you turn key on you can pull whatever code thats causing it . Otherwise you need buds to pull inactive codes .
Ace. It could have been stored in Ecu after I put in a new oil pressure sensor it still was in limp mode but I started it this morning and no limp mode.
When we run our 2019 800R limp mode comes on every time after 45 minutes of riding. I’ve cleaned the radiator multiple times, checked the spark arrester, changed radiator coolant, inspected the drive belt. Any ideas what this could be?
im going to bleed the cooling system to see if it might be an air bubble. Other thoughts?
I have the same BRAKE limp mode issue on my 2021 commander, I will be riding along and suddenly starts flashing and lose power, leave off gas pedal and throttle up again and is fine for a while then same thing? Any suggestions?
If you have a brake limp mode when it's in limp check to see if the brake lights are stuck on . You typically get the brake limp mode when driving with two feet . If you Throttle and touch brake pedal any at all it puts it in limp mode .
No, I’m sure that’s not happening. One other thing that is going on from the time I purchased it, my brake light goes out when I hit the brakes. Wonder if there is something to do with my limp mode issue?
This is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread.
Related Threads
Can-Am Commander Forum
384.4K posts
21.2K members
Since 2009
A forum community dedicated to Can-am Commander side-by-side owners and enthusiasts. Come join the discussion about performance, accessories, specifications, modifications, troubleshooting, maintenance, and more!
