After trying to figure out how to set the clock on the radio which has very limited instructions I decided to e-mail my question to a Jensen representative, below was his response:
Thanks for contacting ASA Electronics. The JWR200B is a wired remote and only provides basic function controls for the stereo. Since BRP has limited space for the stereo, they order just the tuner/amp module of the JMS2212 and use the JWR200B to control the unit. The actual JMS2212 consists of the tuner/amp module and a commander display module. The JMS2212 commander would be required to set the clock and adjust any of the settings. If you want the ability to make adjustments or set the clock, the commander can be purchased separately.
Please see the part numbers below if you are interested upgrading. You can contact our customer service department @ 877-305-0445 for pricing and availability. Please let us know if we can be of any further assistance.
JMS22CM—Commander
JWRCBLS—Y cable to connect both JMS22CM and JWR200 at the same time (not required if only using the JMS22CM)
JWREXT --- Extension cable (if extra length is required)
Thank you,
Willie Calhoun
Technical Services
ASA Electronics
info@asaelectronics.com
So, there you have it, if you want to use the clock or make any adjustments you need to buy an upgrade....Hmmm I thought $20,000.00 plus was a sufficiant amount of money to get a radio in my commander that I could set the dang clock....un-real.....
JMS22CM—Commander
Thank you,
Willie Calhoun
Technical Services
ASA Electronics
