1 - 7 of 7 Posts
2013 1000, I’ve been installing a rad relocation and have been firing the machine up bringing it to temp to burp the system several times over the weekend. Got everything done and machine was running excellent, the following day went to fire it up and nothing, it turns over but won’t fire. It’s reading the rpm on the gauge as it turns over, no codes being thrown.
I’ve changed spark plugs, coils, crank sensor, and also threw a new battery at it, no change, what am I missing?
Do you have one of these technological marvels? If so, you should show 12 volts at the violet/green (#2) wire at the coil with the ignition switched on.
1 - 7 of 7 Posts
