1 - 7 of 7 Posts
problem fixed, was loose wire from secondary ground that attached to bracket that hold the power steering bracket.
Power steering works great. main pro is no more steering wheel jerking when hitting rock and stumps.
I have not done any wiring on this rig. I am also not sure what you mean by a relay zooming sound. From your description it sounds like your battery is gone. Check it with a meter if you have one. I would check again to make sure everything is grounded well and all connections are good. It could be a coincidence that it went at the same time you did the power steering, but probably not. The relay I think is buzzing/chattering because it's not getting enough voltage. That is why switching relays didn't work or at least a possibility. Good luck.
I'm partway through install for wicked bilt on 2012 x . Just wiring left to do pretty easy so far indtructions are excellent. Stopped for a brew 2 hours to mount everything and just wiring left
1 - 7 of 7 Posts
