1 - 6 of 6 Posts
I'm gonna be replacing the inner secondary sheave and helix on my 12 Limited. Should I replace them with the ones for a 2013 that have the torsion spring or just put it back stock? Or will these even work on a 12?
Torsional spring is only thing different. You can use 13 sheaves and helix with 12 spring. I used 12 spring in my 13 4600 miles no issues.
I took mine out at 400 miles not sure it didn't make less noise with it out than when it was in. Definitely didn't get louder.
Discussion Starter · #5 ·
I've read that it's kind of a trick to get (and keep) the ends of the spring inserted and the correct preload put on it as you re-install everything. If there's no benefit I'll just put the original spring back in.
Yeah you stick the ends in the holes. Then twist and push at same time. It's a lot easier with the flat spring. It's just push and start the bolt.
1 - 6 of 6 Posts
