1 - 2 of 2 Posts
I have a 2012 canam commander limited and I hit a stump hard kissed the dash and bent my tie rod can i change just the tie rod or do i have to buy the hole rack and how do i take it apart if i can change the tie rod please help my face hurts :commanderroll::commander:
I believe the answer your looking for is in the shop manual which can be foundwhich can be found on this site with a little bit searching. There is probably pictures and stuff in there too. basically you need to remove the boot by sliding off the rack after you remove the clamp. some of the aftermarket companies include a special crows foot or taking off the stock 1
1 - 2 of 2 Posts
