Adding a horn to a 2020 Commander Max Limited. Is there a specific location for the horn to mount and pre-run wire to the dash for easy installation? All the posts the search came up with were aged.
Most mount them under the diver side fender then just run the wires along the top frame tube into the cab and up to the dash panel. Not seen any pre existing place for them from the factory . And there’s not a tie in on the factory harness for the horn . But if you run a relay you can tap into one of the spare accessory plugs up in the dash that is prewired for other accessories.
My 19 Max XT came with the factory horn. Not sure where it was/is, but it SUCKED. Handful of times getting it wet it eventually died. I threw a $15 harbor freight air-horn under the console. Horns are tied to the bar, compressor tucked away from water. Nice and loud, but doesn't get cows out of the road.
Related Threads
Can-Am Commander Forum
384.4K posts
21.1K members
Since 2009
