Sorry, but i would have to disagree some.If this is the type of riding you do most of the time, I wouldn't worry about power steering. At the speeds you are running power steering is not needed. Slow technical driving is were I see the true benefits of the uni-steer.
Nice video !!!
I would agree as long as you upgrade the rest of the components when you add power steering. I think that if you do the power steering you need to go ahead and do the Rackzilla and HD tie rods along with it. If you "just" have power steering and hit one of those "steering wheel jerker" ruts or bumps and don't upgrade the other components, the force will be transferred into your tie rods and steering rack, busting that instead. That to me would be a much more catastrophic event at high speeds than having the wheel jerked out of your hands. You can at least recover from that as opposed to the other. I think with small bumps and ruts you would be fine with just the power steering, but if we're talking about "ripping" your hand off the steering wheel where you can die, than I think adding all the components together will be the only thing that saves you.Sorry, but i would have to disagree some.If this is the type of riding you do most of the time, I wouldn't worry about power steering. At the speeds you are running power steering is not needed. Slow technical driving is were I see the true benefits of the uni-steer.
Nice video !!!
It keeps you from Dieing , in a high speed crash , caused by a rut,rock,or any smaller obstruction that could jerk the steering out of your hand without power steering . IMO
