Help!!
238 Views 5 Replies 3 Participants Last post by  Moffco
My glove box will not stay closed!!! It does fine till you hit a bump then it’ll pop open. It almost acts like it’s missing a spring to hold tension on the handle. I know this is a minor issue but it is driving my crazy!!!!
1 - 6 of 6 Posts
Check the lip on the latch make sure it hasn’t worn down .
Cut a couple inch long piece of appropriate diameter fuel line. Stick it into the blank space where the latch hinges when you open the glove box. It will act as a spring to keep the latched closed. And it won’t fall out because of the pressure.
Mine just started popping open a year or so ago and it’s been fine since that two minute fix.
I’ll try and take a picture in the morning. And see what size hose it is.
Ok. It’s heater hose - appears roughly 1/2 inside diameter and 7/8 outside. Here’s the pics.
See less See more
2
Reactions: 1
1 - 6 of 6 Posts
