1 - 19 of 19 Posts
Hi,
Not that mechanically inclined, but installing a light bar on my commander X.
I have read that behind the main panel there is an accessory plug to take switched power off (I am using a relay) so just need to power the switch off this.
I want it available on both lights on and lights off position of the key when powered on.
Please could someone let me know which plug I am meant to use from these photos.
thanks and Merry Christmas to all. Grant.
One with the white plug should be fine .i hope you are getting your relay power from the battery
Thanks Troy.
Yes relay will get power from battery directly. Looking just to have the switch on this.
Should I put a busbar on this so as to facilitate future items that need a relay?
My last unit I added a extra fuse box but adding a busbar is a good idea if you plan on adding more stuff
I used the 2 prong weather pak plug for my acc trigger wire for my relays. This is one of the splitters I made. Got the plugs on eBay. Also pics of roof switches and dash. As mentioned, main power to the relays from the battery.
On my commander and maverick they both had 3 unused wires that are switched power. Any of them will work for you . Mine also has a extra switched unused down by the battery . The limited model used the wires in the dash for the gps and radio .
Discussion Starter #10
I have decided to go with the larger black one, simply because it’s easier to open etc.
What size electrical prongs do I need to insert?
They are GM weather pak connectors. I dont know the diameter but you should be able to find them at a parts store. The big 3 prong plug is the factory connector for the winch remote plug which mounts in the glove box, if I recall correctly.
Correct
Discussion Starter #13
unfortunately, living in Africa makes it a small consumer market, and even smaller for UTV's so parts like these are not easy to find.... if at all.
I will probably have to bring them in from Amazon.
I will not be using the winch connectors... my service guy did a superb (over engineered) install of my Superwinch and the way he did it, makes using the Can Am connectors look pedestrian.
thanks for all the help chaps.
You can always cut the plug off and use what you can find local
Not exactly sure if this is the route you want to go, but this is what I used on my arctic cat. Ran 4ga wire from the battery with a 100A breaker that was used as a switch also to completely remove or supply power to the whole bus. Ran 2 light bars, all of my switches, extra cig lighter plugs, and USB plugs off of it. Can also support more stuff. Good for 30a per slot or 100a total.
https://www.amazon.com/gp/aw/d/B001P6FTHC?psc=1&ref=yo_pop_mb_pd_title
Hi all! Just bought a used 2013 Limited. Great info on making power available. Planning on adding accessories, how do I get power to the switch positions in the overhead?
1 - 19 of 19 Posts
