I have 2013 can am commander X 1000. Was running and then cut off. will start and cuts off. I’ve replaced spark plug and fuel pump filters….fuel pump works. Removed and checked injectors and fuel does spray out. Check fuses and all intact. I remove spark plugs and checked for spark and there is spark. I sprayed starter fluid and motor runs and then cuts off. I drained all fuel and replaced fuel and still not running. I have new battery. I replaced foot accelerator pedal. I’m lost and can’t think of anything to do to get this running. Can anyone further help me figure this out?
