2061 - 2080 of 2120 Posts
I think it was a blow machine to install in stinger. This way it won’t start if he blows over 0.2 . Normal folk are on a .08 rule but boogs was born with higher numbers than that .
Troy. C’mon. You’ve known Booger a lot longer than I have. It was a breathalyzer, but I had them set it at 4.0. That way he could at least still drive Stinger after a bowl of cereal. Just one bowl.
Hi all! I’ve been sorting through these threads trying to figure out the Commander lean. (Mostly Mud guys with huge tires.) I guess there is no adjustment on the back side but I have it on the front too. Any help or advice would be much appreciated. Thanks in advance. Boog.
As Acefire would say, 10-4. Thanks for the help. I’ll give that a shot.
Wait till morning then the moon will be in a different spot and it’s gravitational pull will be different on the gas . It might lean the other way
Reactions: Bill_Rowe
Thank you Troy. I’ll give that a shot as well!
Well they say the moon is what controls the tides so maybe your leaning mander
Boogs when my mander was doing the lean I had to replace my rear sway bar .
It was twisted
Reactions: bstromback2002
Just air up the right side front and rear !! Watch it straighten right out. Being both tires are flat !!
But but they were only flat on the bottom
Gee is my face red. Ace nailed it on the head! Ol’ Stinger is sitting pretty now. Thanks everyone for the help. I hope you and yours are safe. Love, Boog.
Hey boogs could you offer some of your wisdom and help me out with some trouble shooting .
My mav is unusually quiet and will not move when I put it into gear . Don’t matter if it’s high low or reverse.
Reactions: slowindown
Dearest Troy, please engage starter button prior to putting machine in gear. Hope this helps. Boog.
100% sound advise .
I got it now
