Need help here guys I have a 2013 can am commander and the head lights wont work
and the switch panel dont light up either
It is probably the headlight relay. It is located in the fuse box by the battery. If you search I have a thread on here about it including the part number. I was able to get a replacement from O'Reilly's fairly cheap. One note, just like any relay, the pins are numbered. Make sure when you pull out the old relay you keep track of which way the new one goes in.
Here’s some pics from the owners manual and shop manual showing locations of the relay and fuses and what does what
65259
65260
65261
