Hello guys not sure I’m putting this in the right discussion but here goes. I have a canam commander sxs it has an hcr longtravel kit with king coil overs and 31” tires it handles woops and jumps like a dream but I get really bad bump steer and it’s a bitch to turn is there any fixes to this thank you
Dps? Power steering? As for bump steering you can try turning rebound clockwise couple click then run it again. If its better go a couple more. I'm hoping with LT kit you good some good tie rods and heavy joints. With 30" rubber the you need all the rod you can get and good power steering. What yr is the machine?
Also if low speed compression is to high it can cause bump steer / cause of lack of traction it will bump steer threw the turns or push if turn is smooth . You should be able to dial it in to where you point it it goes there at any speed.
Discussion Starter · #4 ·
It’s a 2012 I bought it off a race team I’m on my second rack and pinion I think because the bump steer
