1 - 8 of 8 Posts
About to do my annual oil change and previously used the K&N 152 oil filter. Curious if this is still considered a good choice or if there is another out on the market that is as good or better? I did see something about some of the 152 filters not coming with the rubber o ring on the end and should not be used.
Troy also found some of the 152 filter were like 2mm shorter allowing oil to bypass around them.
If you can find the wix that would be my choice .
1 - 8 of 8 Posts
