141 - 160 of 176 Posts
Discussion Starter #141
Looking at your pictures and looking at mine That doesn’t belong there does it that’s the shim I hope
Discussion Starter #148
While I have this apart I might as will put a new spring and helix in it what am I looking for guys help me out
Are the bolt holes in the plastic still good or have they been drilled out? Did it have the o-rings yet? Just checking.
Discussion Starter #152
O
rings were good the holes had the spacers in the plastics doesn’t look like nothing was drilled out I just put the old screws with washers to hold it on until I get new ones
Discussion Starter #154
Back to that helix in Spring what am I looking for anything special no I’m not out there beating the brakes off this thing well sometimes but
The top 2 holes on that back cover should be recessed bolts. Go to www.canampartsguy.com and lookup your cover and compare. The bolts are sticking out to far believe they will rub on your clutch. Forget about everything else until you get that back cover squared away properly
Discussion Starter #156
The screws are too long I just have two washers holding it on their temporary they do recess
Still don’t understand why put that shim
in there
If the previous owner put on an aftermarket clutch, and it was a thicker assembly than original, it would rub the outer clutch cover. If he or she were to shim the housing backplate, it would move the cover out, since the cover is attached to the backplate. That would also explain why the inside of the clutch is now rubbing the backplate or shim, since the lateral location of the clutch doesn't change relative to the crankshaft. The only other reason I could think of to shim the housing out would be to create a place to keep Slim Jims or jerky strips warm. Even if the clutch you have now is not thicker, he or she may have had a thicker one on before. Sometimes owners experiment with clutches.
Discussion Starter #158
Yeah the slim Jim thing sounds about right LOL but anyhow thanks guys thanks a lot anybody on the helix and spring what am I looking for
Ok sounds good your bolts. I can’t imagine what kind of clutch would require doing something like that. Was there a shim on the tranny also?
