281 - 300 of 305 Posts
Easier with two people a hulk to push it together and one to start the bolt . I used a 2x4 to wedge it in place with one have and other to start the bolt. Just make sure you got at least 3 threads started or it may blow back off at ya.
That's how I do it. Its sketchy!!
Discussion Starter #287
Wouldn't be right if I took all the fun away from you!
Don't be scurred. Rip into it.
Elves only like fixing shoes in the middle of the night.
None have ever surprised me with a fixed gearbox in the morning.
Discussion Starter #293
Rear Brake lights do not come on when I hit the brake pedal.
How do I fix that?
Is that just the Brake Switch?
#61 in this pic.
66259
Reactions: UPfreebird
Yep. That’s the Oem one. So you don’t have to switch the connector.
Another bonus to having the brake lights work in addition to having brake lights and starting in gear is that you can reset your maintenance required message. You can’t do it unless the brake press switch works.
Discussion Starter #299
Good to know.
Also makes sense as to why I couldn't get my Maintenance Required message to go away.
