1 - 3 of 3 Posts
Hello
I have 2013 can am 800 xt and my gear shift is hard to move from p,d,n,h,l
And when I turn key on sometimes I hear no noise
Any help be nice
Disconnect the shifter cable from the transmission try moving it then. If it’s hard to move replace the cable. When you turn the key on you should hear the fuel pump cycle every time.
When is it hard to shift both running and not? If it slides freely with engine not running sounds like typical one way bearing in primary clutch dragging and keeping tension on gearbox internals. And for no noise turning key on if the pump has primed up the system and your not waiting long enuff it may not but I'm unclear on what your saying about that issue..
1 - 3 of 3 Posts
