21 - 30 of 30 Posts
Well my maverick fuel tank started leaking on the filler neck this weekend . Because of my cab things get very stinky inside .
Naturally I can’t find my spare tank that I bought .
Want me to see it’s on Stingers parts shelf?
Sure boogs see if you have it
So how can you fix this neck leaking issue? Could you JB weld it, or do you have to replace the tank?
Wouldn’t be the first tank I have welded . But it also depends on the metal . If it’s from rust it’s junk . If it’s cracked it can be welded. With the proper equipment.
Not found any epoxy that would hold on gas tanks . They have all been temporary fixes. Then a lot harder to clean up to weld .
Sealall should work to stop the leak on the fuel neck . It don’t cure hard . It stays a bit soft . Because it’s not hard it should stay stuck on . I will try it until I can find my spare tank lol
21 - 30 of 30 Posts
