1 - 20 of 36 Posts
Is the only filter on the 2013 commander 1000 a sock on the fuel pump?
I found it. Started stumbling on take off and then runs out of gas if you try and stomp on it. Fuel pump hums but doesn't sound as loud. Is the fuel regulator built on the top of the pump assembly?
So that is not a pressure relief diaphragm on top? Sure looked like one.
You know the sad part is I've owned this new since 2013 and it has only 108 hrs. on it.
Discussion Starter #11
Okay. Rebuilt the pump assembly and still does not have any power. Won't idle long and will backfire if you Rev it up. I installed a fuel gauge in the line and get a steady 40 psi at idle or revving it. I know that is a little low but it is a cheap harbor freight fuel injector pump tester. Not sure how accurate it is. No warning lights or messages on the display. I haven't checked for any diagnostic codes. If there were wouldn't I get a warning light?
Discussion Starter #13
It is a brand new pump. Doing the same thing the old pump was. I didn't check the fuel pressure though while the old pump was in there.
Regarding post 11
Sorry. I misunderstood. I thought you were just trying to fix the old pump.
The circled part is the fuel pressure regulator
I had one of them fail on a customer unit . The pump kits I have been buying comes with a new one . The pressure regulator can stick open or closed when they fail
Discussion Starter #19
It is a new one that came with the pump kit. It was supposed to be a rebuild kit for the 1000 but I'm wondering if it may have been for another unit that runs at a lower fuel pressure. Shoots right up to about 42 pounds and then holds steady at 40 when trying to run.
1 - 20 of 36 Posts
