41 - 46 of 46 Posts
Discussion Starter #41
There is a slight gap between the two inner races which looks the same on the old and new bearings including the bearing on the other wheel. Definitely bearing resistance, will pump grease thru tool when not installed.
Discussion Starter #42
I just ordered the Milwaukee couplers that acefire posted. Found them on ebay for $13.35 for two. I'll see if they help
Discussion Starter #46
Just to follow up, the new coupler solved the problem, both bearing took grease without leaking out of the coupler. I noticed that my old couplers only had two jaws to connect around the zerk. The Milwaukee has four. Thanks for everyone's help and suggestions
41 - 46 of 46 Posts
