I have a 2012 Cannabder LLTD I have owned it for a few years, and from the beginning, it has never really tracked down the road straight, it has 6” and 35” tires, so I chalked it up to that. Recently I switched tires and went with something that had a bit less aggressive tread thinking that may help a bit, that was not the sole reason for the switch, but I was hoping. Still the same. Also, it has always pulled to the right while driving and when braking, so I thought maybe an alignment is in order. There was only about a 3/8 difference in the rear measurement, so a slight tow-in, I have scratched that off the list. Today I put the front end in the air, both front wheels have a side-to-side play, from 9 to 3. I had someone hold the steering wheel tight, and the wheels still moved With the steering wheel held tight, and one hand on the steering arm, I can still move the wheel side to side without the steering arm moving. So I assume that the hubs are nad, but I defer to the group for input. I recently had new front bearing installed, there is no 12-6 play on either side.
