I was finally trying to mess with my fox shocks and change the high speed compression but the blue adjustment screw is stuck on the drivers side rear. Each time I try to turn it the piece of metal being it that says “high speed” turns and not the actual blue adjustment screw. I tried holding that with some lock pliers while trying to loosen the blue adjustment screw with no luck. Any ideas or suggestions are appreciated... should I try spraying the screw with wd 40 or something similar?
