Swapped relay with Accy. relay same one and made no difference all is still the same.Service manual says that the fan relay is activated by the ECM, with input from the coolant temperature sensor and/or the intake manifold pressure/temperature sensor.
You are 100% correct , that's how it works . Bollax did you try a new relay , as a bad one can't do weird things sometimes
Sent from my iPhone using Tapatalk 2
OK tried that, no bars show after 10 min idle but check engine light and message appeared.Bolax, just for giggles, pull the fan relay out and start the machine. Let it warm up to above the halfway point and plug it back in. Report back what happens.
Jeremy
Started w/o the relay installed and it ran for ten (10) minutes with no bars showing, just the check engine message. no bars at all ?Did you let it warm up to where the fan would normally kick on before plugging back in?
Sent from my XT1080 using Tapatalk
Well second try is the Charm.Bolax, just for giggles, pull the fan relay out and start the machine. Let it warm up to above the halfway point and plug it back in. Report back what happens.
Jeremy
I Dont know why but, it did for me so I thought I would pass on the info...call it the jbee fan fixWell second try is the Charm.Bolax, just for giggles, pull the fan relay out and start the machine. Let it warm up to above the halfway point and plug it back in. Report back what happens.
Jeremy
Let it cool back down and tried the routine again and it worked. put the relay back in at two bars and no fan.
looks like problem solved.
On to the next one.
Why did that work, what was / is the process ?
Is it a reset ?
Thanx again,
Ed
Cool.I Dont know why but, it did for me so I thought I would pass on the info...call it the jbee fan fixWell second try is the Charm.Bolax, just for giggles, pull the fan relay out and start the machine. Let it warm up to above the halfway point and plug it back in. Report back what happens.
Jeremy
On to the next one.
Is it a reset ?
Thanx again,
Ed
Interesting side bar to Fan problem.Cool.I Dont know why but, it did for me so I thought I would pass on the info...call it the jbee fan fixWell second try is the Charm.
On to the next one.
Is it a reset ?
Thanx again,
Ed
Thanx again
Guess I g\have to bump it to keep it alive?Interesting side bar to Fan problem.Cool.I Dont know why but, it did for me so I thought I would pass on the info...call it the jbee fan fix
Thanx again
Jbee's idea worked, except after 88 miles at 3,000 ft ASL and 95deg. ambient temp running on pavement at 55 to 65 mph and parking the ride for six (6) hours on start up issue returned.
On the reverse ride home the fan came on at cold start up, on the ride home the temp bars reached six (6) for a while again at 3,000 ft & 55 to 65 mph on blacktop with same temp. Slowed to about 45 for a couple miles bars went to four (4) and then to three (3) had to stop for a Military check point for about five (5) minutes and all was back to normal three (3) bars and no fan, turned on the DZ fan control and rode the last 50 miles at 55 to 60 at two / three bars. The altitude does contribute to the temp as well as fuel economy.
I guess gremlins come & gremlins go.
Still would like to know what happened.
FYI We were running as chase vehicle for the Baja 500 race so that's the pavement, speed & altitude answer.
