Usually answering problems, now it's my turn LOL
Fan constantly runs from ignition on until ignition off, gauge shows four (4) bars.
Disconnected DZ fan switch and plugged fan back into OEM harness, made no difference.
So It is nothing to do with fan over ride.
Any clues as to what it might be.
Rad is clean, coolant level is proper and not been apart for over 2,000 miles so it's not a bleed issue ?
If I disconnect the fan at the Rad. plug no fan so juice to fan motor is good.
Any advise from similar issues ?
Where is the fan relay located ?
Where is the fan sensor located ?
