1 - 20 of 29 Posts
Has anyone ever had there factory warn winch die? Mine wouldn't work and you could here the solenoid clicking. If I tapped on it a few times it would start turning very slowly and start to gain speed but as soon as I let off the switch I had to beat it again.
So is the motor shot? Do I just throw it in the trash and get a new one? Or can I take it apart and fix it?
all the above, i've taken apart one a LONG time ago, it was full of muddy water, likely same as yours if you've been in the soup.
or they are not to much, go get a new one.
Lol mine has been buried many many times!! Went to hook up the plow today and this happened.
I’d fix it myself. Most the warn stuff in my experience when working slow just needs a little maintenance. If it stopped working completely then yeah new solenoid or other parts.
With your money just buy a new one and send me the old one so I can have two.
Lol you funny boogs.
Sometimes just a pain in the but
My warn solenoid died last summer. Took it apart and it was clean as new. Worked maybe once or twice after that and it was dead again. Buy a replacement and change it so your not stranded. I went with another warn but there was lots of aftermarket units available.
Call me lucky with the factory winch (I guess) 3 seasons of plowing,log dragging and the occasional get me out! On my 3rd contactor box tho??
Sounds like sticky brushes in winch motor. Had that happen on my plow trucks time and again.
Use booster cables from a battery and go direct to the winch and then you will know . If it spins the winch motor fine it’s contactor trouble . If the winch spins slow while being tested it’s the winch motor
Discussion Starter #13
Newbie here with messing with a winch. So how do I do it?? Ground to the frame and positive to either terminal?
Winch has two large wires that bolt to it . Clamp your booster cables to them . Pull a couple feet of cable out from the winch so nothing binds during your test . Ok your cables are clamped on the winch motor so now take the other end of your booster cables and go to a battery . Clamp one on the battery and then do the other and watch your winch motor . Reversing the cables on the battery will change the direction it turns
Discussion Starter #15
Ok easy enough I got a good jump box and I accidentally pulled all the cable off trying to straighten it out
You need to hook up to the studs coming out of the winch motor. Don’t let your jumper cables touch the motor as you want your battery power to go into the winch motor and not make a bunch of sparks from grounding out on the winch motor body . Only hook up to the studs . I have clamped Vise-grip’s on the studs so I have a bigger thing’s to hook my jumper cables too .
If one of power cable’s fell apart just by moving it a bit you might have found your winch trouble anyway .
Discussion Starter #18
If your cable fell apart just by moving it a bit you might have found your winch trouble anyway .
Lol no the winch cable itself. Was rolling the machine backwards while tied to the semi and apparently the commander and winch cable weren't up to pulling 20,000 lbs
You should take a video of you doing the motor test .
Discussion Starter #20
Lol first I need to get off the couch but ya I'll get to it shortly
1 - 20 of 29 Posts
