I just changed this out for the lower rpm engagment spring.it didnt engage until 2200 rpm.just wondering if this is a after market or factory spring.
I like it took out alot of the jerking when taking off.I think that may be factory. If I get near my box-o-commander stuff I’ll verify.
So how you liking the low speed engagement spring? I’ve been very happy with mine.
Where did you guys get your lower rpm engagement springs? Cuz the one i ordered from UATV-TECH didnt change my engagement at all...I like it took out alot of the jerking when taking off.
Mine engaged at 2200 before and after the swap, where does yours engage?Uatv-tech
worked on mine
Couple of things: 1) at least on mine, I'm rolling before I register 1mph, 2) there is variance when I'm getting engagement - from 1400 to 1800 - really tough to keep it steady enough to be sure - you can feel it start to grab 3) when mine gets too jerky taking off, I sand the side of my belt, scotch brite the sheave faces and check that the flyweights are swinging freely, 4) I'm running the maverick belt (2700ish miles on it) which I believe is a hair wider than the commander belt and 5) here's a couple of videos I just made - it's on flat road and I'm rolling well before it shows 1mph (you can see this especially in the first vid):These are screenshots of before and after videos, both taken as soon as the machine registered 1mph...
Still very much in the jerky stages of beginning to move from a stop, the engagement seems to be the same to me... definitely aint in the 1600-1700 range like i would like
And actually if you take the Didgital tachs word for it the lower engagement spring is worse than the factory one
