21 - 40 of 61 Posts
Not sure if it is the best thing to do but I give it a shot with my pressure washer in the outlet when I wash my machine then run it for a while.
Neil.
Neil.
Anytime you spray water back in the muffle you just asking for trouble. The inside of the muffle will rust first . And yes if you run it the water will evaporate but the mud and dirt will stay in there for ever. The muffler body is a low extremely low grade of stainless but the baffles are mild steel.
Neil.
I was wondering if that would be not such a good idea? Maybe if this is a problem often make a pop in snorkel for the pig bath times and remove when out?
Discussion Starter #24
Nope this way works fine . I have being doing it this way for years . After about six times your threads on your bolt start showing stress
Discussion Starter #27
Thanks. I ordered the inserts like the ones linked above except from ebay. The ones on amazon had a really late projected delivery date unless I allowed them to dry rape me on shipping. I'm going to check at fastenal next week to see what they have but all they show online are round ones.
Discussion Starter #28
Look what the mailman brought. Fit perfect. Ill make the little tool and install them later.
If anyone needs a few let me know and I'll drop them in the mail. I can share with several people at least.
Good find
Discussion Starter #30
The little tool like in the video worked good. I just used a little piece of scrap strap metal I found.
Now I have 47 more of these cool little dodads and nothing I can cut a hex hole with.
That should be enough to last the life expectancy of the muffler lol I tig welded the oem ones in guess if they ever rip out I'm gonna turn the outlet a few degrees and try again
Discussion Starter #32
Ha. Yeah. I don't have anything but a little stick welder. And like I said, if anyone needs some of these I don't mind giving some away.
That's the cleanest work bench I've seen yet!!
Oh - boy I wouldn't try that with my wife . If I put a muffler on my wife's counter I would never here the end of it .
I see in the background you have the necessary fluids close at hand to stay hydrated throughout the project.
Discussion Starter #37
Yeah she had this strange expression when I heated up the gearbox cover in the oven so I could put the new bearing in it. I had assumed it was sincere deep admiration and love... But, now that you mention it, I suppose it could have been something else...
After reading this post I was a little nervous about cleaning my spark arrester for the first time. My bolts came out fairly easy then I squirted penetrating fluid into the holes and ran the bolts in and out to clean holes. I used anti-seize during final assembly. On the muffler cover I removed the two lower and upper bolt on the tip side. I just loosened the other one and swung the cover out of the way. I just thought this might save somebody the pain slowindown went through. Booger.
Discussion Starter #40
Yeah. Good point. Get them out and save the inserts before it's too late.
What contributed to mine was that while I bought a low time low mileage machine, it had been used in water and mud a lot. Hopefully I'm about past all of the issues that sort of use caused. Knock on wood...
21 - 40 of 61 Posts
