1 - 20 of 30 Posts
I’ve had my 2014 800XT since new and mainly use it for trail riding in Colorado.
I’ve never thought that the engine braking system worked that great. When descending a steep hill I can tell that it holds the machine back at first, but never keeps it as slow as I would like. It just keeps gaining speed and I finally have to get on the brakes to get it under control. This happens in high and low range.
It has about 530 miles on it now and about 70 hours.
I’ve read as many posts as I can find on engine braking, but none of them have helped much on my problem.
What do other think of the engine braking system?
Engine break should be really good in the stock clutch . If it’s speeding up something isn’t right .
Thanks for the comment. Around where I ride, there is one guy in the group that has a 2012 800, when I follow him downhill, I never see his brake lights come on. He rode with me today and thought that it did not perform like his does. His and my machine are both stock.
I seem to have all the power I need, so I don’t feel like I have a belt issue.
What acefire said & has the 1 way ever been serviced, if so by who ??. & when mileage wise ?
I don’t think the one way bearing has been serviced. I have suspected it might be a possibility. I suspect it has been issue since new, but this was the first Can Am I have owned.
My previous atv was a Polaris 800 Sportsman. It had the EBS feature on it and it seemed to work vary well.
What Acefire said. Something must be amiss. I have a stock '12 xt1000, and engine braking is outstanding. It is why I keep my stock clutching in spite of it's other shortcomings.
Those little springs and cups are what your looking for. There’s two of each 180° from each other under the oneway bearing .
1 thing to note:
Those little springs and cups will launch like a Patriot Rocket when you slide that race forward, so beware of projectiles as they will disappear in a hurry, if you don't capture the little Boogers :sad:
Little Boogers lol
Discussion Starter #16
I dropped it off at a local dealer in Colorado yesterday with instructions to inspect the drive system. I don’t have access to tools and a place to work on it in Colorado, so I am at the mercy of the dealer. Hope I chose wisely!
What dealer?
Discussion Starter #18
I took it to Fremont Motorsports, it was the closest dealer to me. I live just north of Salida.
10-4, good luck. I’m just Northeast of Denver in Henderson. If you are up this way and need assistance let me know. I will do what I can just like everyone else I’ve met on this forum.
1 - 20 of 30 Posts
