Has anyone tried a power windshield to combat the dust in cab? By cracking it open slightly.
Thanks buying one now.If you don't have a back window and are running a front you will never stop the cab dust. The dust is baxk drafting into the cab do to the front blocking the wind. I know the guys run power windshield them wide open in summer to help keep the heat down . But most have the rear as well.
Thank you buying one now.If you don't have a back window and are running a front you will never stop the cab dust. The dust is baxk drafting into the cab do to the front blocking the wind. I know the guys run power windshield them wide open in summer to help keep the heat down . But most have the rear as well.
What kind works best? This one ok? 2021+ Can-Am Commander Rear WindshieldIf you don't have a back window and are running a front you will never stop the cab dust. The dust is baxk drafting into the cab do to the front blocking the wind. I know the guys run power windshield them wide open in summer to help keep the heat down . But most have the rear as well.
So you run it open 8 inches correct? Thank you for the input sick of being a dust ball.I run a tilt windshield and ride the Arizona desert and when open about 8-10” i get VERY Little dust—No back window !!! Would like a power flip on my next machine !!!!
It will open about 8”—you can also remove completely in about 30 seconds-So you run it open 8 inches correct? Thank you for the input sick of being a dust ball.
