1 - 7 of 7 Posts
I know someone has wrote about the PITA bolt for the drivers side net just to get the under seat plastics off but can't find anything.
Please tell me the truck to fix this.
Don't want to fight this when I'm out in BFE and need to replace a belt.
I'm thinking of putting the bolt in from under set toward to peddles, cut bottom of plastic and use a 2nd nut for the net. Or cut that strap off. Haha
Sent from my SM-G973U using Tapatalk
Discussion Starter #2
This is my fix for the net strap.
I mean here it is. Haha
I did a similar thing to mine only used a plastic collar over the stud for the strap buckle to pivot on then a fender washer and wing nut to hold it all together. With a wing nut I can easily remove the strap without tools to get the seat out without using tools.
That's a great idea with the wingnut golf cart That's getting changed tonight!
It's worked out fine and makes the seat so much easier to remove. I also cut slots in the plastic panels as Syon had done to make the panels easier to remove.. I tighten it by hand and have not had an issue with it loosening on it's own. Allowing the strap belt to be able to pivot prevents the buckle from loosening the nut.
When removing the nut just be careful not to drop it into the hole in the floor panel into never-never land!
1 - 7 of 7 Posts
