1 - 17 of 17 Posts
I posted a while back about my display acting up. Got it working and it died again so was going to order a XT cluster. I know dealer will have to flash it, but do they use the same mount? I've been looking at parts diagrams and can't tell.
Discussion Starter #2
Update, I found the correct mount. Is there another cover or other parts needed to complete the swap?
Cool, I appreciate it. Looking forward to the swap. I've read some info on it, but they're mostly geared towards the electrical part. Couldn't find anything on mounting it.
I have a cluster off a 800. But the mounts are different on the quad and with the xmr snorkel I haven’t figured out if it will fit yet.
2019 commander 1000r
So just the mount ring and there's no other trim or anything that goes around it?
I just did this swap on my 2019 commander ..dps to xt ...make sure you buy the correct year cluster ..
I just did this swap on a 2019 commander ..make sure you buy the correct year cluster ..and you need mounting bracket and cluster cover and the screws for the cover..mine did not need to be flashed everything works but is on kilometer instead of mph..hope this helps..by the way all mounting brackets and covers are the same.. only the clusters are different as far as year ...to the best of my knowledge
Did you get the swap done.
What issues are you having with the stock cluster?
Discussion Starter #13
Hooked up and worked fine. Did have to have dealer change to mph. Does take a different mount, my original just quit. Wouldn't display anything.
1 - 17 of 17 Posts
