Noticed that I can fell a "lunge" or a drop of power very quickly when cruising at 30-40mph. Kinda feels like you let off of the throttle for a split second. I got to watching my voltage read out on my USB plug and found that the voltage drops tremendously when the fan kicks on. Sometimes it will go as los as 11 VDC. Voltage does recover quickly. Quickly as in 5-6 seconds. Battery is a brand spankn new Interstate. I replaced it as it was getting slow crank and it was the OG battery that came with the machine. Had the same problem with the OG battery and thought this might solve my problem so...I figured that it'd had a pretty good run and was time for a replacement. Playing around, I let it set and idle until it got hot enough for the fan to kick on and it died. It'll fire right back up but at idle the voltage drop kills the engine. Fan seems to work just fine. Doesn't seem to be making any noise or anything out of the ordinary. Voltage regulator? Think the fan drawing too many amps?
