1 - 6 of 6 Posts
Can you just replace the blades on a cooling fan? I just ourchased a 2011 Can Am Commander and when fan kicked on made an awful noise.it was making radiater bounce up and down.i checked blades and one is broke off and one is bent.the moter works good.
You can, but it's not sold separately. You might find a used one, where someone replaced the assembly because of a bad motor, and maybe saved the old shroud and blade.
I think I may have a complete fan and maybe a blade. I will check the blade tonight when I get home I know the complete fan is good.
2018 commander 800
You can buy one of the universals at the local parts store and fit the motor and blades in the factory shroud. For future reference
1 - 6 of 6 Posts
