1 - 9 of 9 Posts
I've looked through the manual and there are individual listings of torque settings from spark plugs to lug nuts, however you'll need to do a search to find each one.
Does anyone have a cheat sheet with all the common torque settings listed?
I'd copy and paste, but the disc will not permit that function :- (
Here is a start:
Gearbox drain plug = 15 lbf/ft (180 lbf/in)
Gearbox filler plug = 3.7 lbf/ft (44 lbf/in)
Front diff drain plug = 5.5 lbf/ft ( 66 lbf/in)
Front diff filler plug = 17 lbf/ft (204 lbf/in)
Rear diff drain plug = 5.5 lbf/ft (66 lbf/in)
Rear diff filler plug = 17 lbf/ft (204 lbf/in)
Main oil Drain plug = 22 lbf/ft (264 lbf/in)
Oil Filter screws = 7.4 lbf/ft (89 lbf/in)
CVT cover screws = 5.1 lbf/ft (62lbf/in)
Main Head Bolts - 15 lbf-ft then 44 lbf-ft (Criss-cross sequence)
Small Head Bolts - 89 in-lbs
Cam Sprocket Bolt - 22 ft-lbs (Loctite)
Cam Retainer Bolt -89 in-lbs
Cam Tensioner Bolts - 53 in-lbs (Loctite)
Crank Sensor Bolt - 89 in-lbs
Valve Cover Screws - 62 in-lbs
will it allow highlight and Ctrl C?
Nope..... if you open the permission details it says content copying is "not allowed". Which means it will not work :mad:
I can highlight but there is no function for copy (it's grayed out)
Printing is of course allowed.
Cylinder Head Screw Torque are interesting.....
torque in criss-cross sequence
15 ft/lb then finish by tightening to 180º +/- 5º
TORQUE SPECS
Valve Cover Bolts - 62 in-lbs
This is for the 800s.
Discussion Starter #6 (Edited)
TORQUE SPECS
Everything looks the same, but they call the valve cover bolts.... "valve cover screws"
This will be a work in progress....... I've edited the first post in this string
Anyone know the torque specs for the 2 bolts holding the water neck down? Im installing the aftermarket aluminum ones now
1 - 9 of 9 Posts
