That's an interesting fix, would never have considered that to be honest, and talk about simple...
That's an interesting fix, would never have considered that to be honest, and talk about simple...Clean the key!! It has a chip, mine did the same thing, Brillo pad, lightly, works great
do you have a pet number for that solenoid? I’m leaning towards that directionGot the exact same issue going on with my '12 Commander 1000 XT. Starts OK cold (cranks slow though), and once the engine is warm after a bit of riding, I get 1 or 2 cranks from the starter and is quits. My battery is 12.78 volts at rest, and only drops to 10.36 volts after turning on the headlights for 2 minutes and then cranking to test voltage drop. Bought a starter rebuild kit and was going to install it yesterday, but decided to test the Solenoid first. Am only getting 10 volts to the starter + post when cranking, and only 10 volts at the Solenoid output terminal too. It shows 12.78 volts at the Solenoid battery side though, so that is too much voltage drop across the Solenoid according to the test procedure I printed out... I'm online ordering a Solenoid as I write this and we'll see how it goes from there... You can get the test procedures from the ManualsLib.com website which details how to test the key switch, start button, Solenoid, Solenoid windings, and starter... I'd recommend doing those tests before you assume it's your starter and tear into the CVT, clutches, etc. to get at it... It would suck to do all that work to replace the starter only to find out later it's your Solenoid, ignition switch, or key switch.... :wink
will check thanksSee post #28. You should see close to 14 volts at battery when running.
Ok ... 12.8 volts while running ... how do you find your blog on the forum ...will check thanks
Thanks checking nowThat should be your actual battery voltage, so it's not charging. You should check your stator output first. If that's good, then replace the regulator/rectifier. And I would not recommend using an aftermarket regulator. Others have had poor results with them.
