I wanted to see if you could buy a drivers seat base for a 2019 commander that can slide back and forth and mount it on passages side to do the same? I would like to have both front seats adjustable. Can this be done?
Thank you
Can’t say on the new ones but they old ones you could. If the seat mounts are the same from left to right . Move your driver over to pass and try it out.
I pulled a set from a 2014 maverick, i used the driver seat on my pass side because the outer was torn so I put it on the inside on the pass side, my mander is a 18
Thanks for the reply. Where you able to adjust passenger seat up and back? Did it bolt right in or did you have to modify? Thanks
I didn't actually use the framework, only the seats themselves, the frame work on them is quiet a bit different, not gonna say they can't be made work, but it'll take some cutting and welding 2 frame works. As far as dropping the whole driver assembly into pass side, no definitely not.
