Alright so after tons of reading and understanding how these clutches work and what parts are which, etc I've decided I want to probably make some sort of move on my primary clutch on my 2018 commander 1000R, but have a few questions yet. I may as well start off with the simplest one of them all that way if I hear something good we can avoid the other questions for plan B.
So my commander runs a maverick 1000R primary and secondary clutch setup. What advantage would I have doing a turbo maverick inner and governor over simply getting Ed to do the lockup mod for a little over $200? It seems the lockup mod prevents slipping of the belt by (edit) locking the inner and outer together. Same thing the maverick turbo setup would do. Anyone with experiences and good results with this?
Next is I've seen mention of a primary spring swap. I've found a low engagement spring on Ed's website (uatv). Is this a mod worth doing? Good results? No issues with running it the lockup mod correct? I've also seen dalton kits, but the best i can understand after reading is they're mainly for rigs with larger tires.
As far as secondary goes I've seen where on stock setups (which is what I have or at most go to 28" tires) there's really no point in doing anything. But I have seen mention before of swapping the (edit) secondary spring as well. Any insight on this?
