Did you Break in the belt first?
I have yet to remove and dis-assemble my clutch on the commander, but I have removed, serviced, and rebuilt snowmobile clutches since I was old enough to turn a wrench. my question is, how can the outer sheave on the primary clutch spin at a different speed than the inner sheave? is the shaft not splined or is it a taper shaft on the fixed half? even with a tapered shaft there should be zero independant movement of the sheaves in relation to each other. please enlighten meIt's cause the stock clutches are garbage. The reason you had imperfections on one side of the belt is because the crank side of the primary, when under a heavy load, will spin faster than the outer part, in turn ruining a belt.
We haven't ever had this issue a QSC Primary.
It's actually just the opposite. The inner part spins faster than the outer (when under a load) because it's attached to the crank. Not at all times. 90%of the time they work in unison. And yes, it's a 2 piece design, not bolted/pinned/splined together like other designs. Pull ANY belt off of ANY can am with stock clutching and look at the inside of the belt. It'll be glazed more or will have torn threads. It is impossible to lock them together. The only thing that holds the sheaves together is the tension and force that it gets from torquing down the primary bolt. Like I said it's a terrible design. Have you pulled your belt box off? You should pull the primary apart and look for yourself. When you replace your belt make sure you clean your clutches really well. It'll help prolong the life of your next belt. Or if you want a QSC primary hit me up, I can get you taken care of.I have yet to remove and dis-assemble my clutch on the commander, but I have removed, serviced, and rebuilt snowmobile clutches since I was old enough to turn a wrench. my question is, how can the outer sheave on the primary clutch spin at a different speed than the inner sheave? is the shaft not splined or is it a taper shaft on the fixed half? even with a tapered shaft there should be zero independant movement of the sheaves in relation to each other. please enlighten meIt's cause the stock clutches are garbage. The reason you had imperfections on one side of the belt is because the crank side of the primary, when under a heavy load, will spin faster than the outer part, in turn ruining a belt.
the clutches on my newer sleds are indexed so that they are assembled the same every time. I have never seen the index marks mis-aligned anytime I have removed them. my sleds are putting out a lot more hp than my commander. my older sleds had splined shafts to connect the halves, the newer stuff is tapered fit.the inner sheave is counterbored with a taper, to fit the tapered crankshaft. just like any typical snowmobile setup, the inner half of the clutch fits the tapered crank.
the outermost end of that inner clutch sheave is counterbored and tapered as well. i dont have exact measurements but i would say somewhere around a 3-1 taper.
the outer movable sheave of the clutch and spyder is all aluminum. the outer spyder has a male taper machined into the center to affix to the female taper on the inner shaft.
the aluminum outer assembly is held and pressed against the steel hardened inner assembly only by the tension of the primary bolt. although you are familiar with tapers, and you know a clutch should never slip on a taper, you have apparently never used dis-similar metals to create tapers. this aluminum/steel contact will easily slip, and it is designed to do so. the outer half of the clutch is designed to slip under loads. look at the inner bore of the fixed sheave shaft after you pull the outer half of your clutch off. that hardened black taper will be shiny silver from the outer half of the aluminnum clutch slipping in the taper.
Most definitelyKris, is it beneficial to run just the QSC primary ?
Did you get any assistance from your dealer on warranty work?mine did the same thing at about 350 miles running straight on pavement and then boom belt in 1000 pieces
I still have a problem with believing the primary clutch moveable sheave is designed to slip on the taper under load.the inner sheave is counterbored with a taper, to fit the tapered crankshaft. just like any typical snowmobile setup, the inner half of the clutch fits the tapered crank.
heres a pic of the culprit, the outer sheave will slip.I have yet to remove and dis-assemble my clutch on the commander, but I have removed, serviced, and rebuilt snowmobile clutches since I was old enough to turn a wrench. my question is, how can the outer sheave on the primary clutch spin at a different speed than the inner sheave? is the shaft not splined or is it a taper shaft on the fixed half? even with a tapered shaft there should be zero independant movement of the sheaves in relation to each other. please enlighten meIt's cause the stock clutches are garbage. The reason you had imperfections on one side of the belt is because the crank side of the primary, when under a heavy load, will spin faster than the outer part, in turn ruining a belt.
