1 - 9 of 9 Posts
Hi all,
I need a replacement rear diff for a 2012 Commander. Part number I believe is 703501019. I will need to ship to SA but can collect and arrange my own courier.
Thanks in advance
So what are you actually needing?
The complete unit that houses the crown and pinion and connects the drive shaft at right angles to the half shafts.
Gears are both damaged and I'm told it's not really worth a rebuild.
Looking for new or used? You can buy the updated rear diff from dealers for 700 ish. For 2012 model you can't use a 14 or 15 model diff they don't fit . 16 and up are the newest updated with helical gears instead of the straight cut.
1 - 9 of 9 Posts
