So guys I've never really had to go super fast with my machine but when I first got it it would go over 60 and you could feel it shift. But it doesn't seem to be shifting into its final gear and max speed is 52-55
What's your rpm? If it's running a really high rpm, it could be that your motor or gearbox seal is getting oil on to the belt. The gearbox seal seems more likely from posts I've seen.
The 800 machines should do 68-70 and the 1000 should do 70-74, maybe more with the newer 1000s. I assume the maxes are a little slower.
The normal key limits it to around 40 M.P.H. I think so the wrong key probably isn’t the issue buy I thought I would throw it out there.
Aftermarket tires that have more mass than stock tires will steal top speed
