1 - 10 of 10 Posts
Keep burping make sure radiator is spotless all the way through the bottom section of RAD. If that doesn't help thermostat.
I removed the thermostat. I will try burping some more. Been thinking it might be water pump. Can u think of a good way to check it without taking it off ?
If you removed the thermostat and blocked the bypass off then you should see water flow when fill cap is off.
My 800 when I drain the coolant system is a wierd bird, I have to pull the top radiator hose off and fill the radiator with coolant that way first before, never had another i had to do that too, but give that a shot. Mine would heat up in about 45 seconds other wise.
1 - 10 of 10 Posts
