Troy,tell me please, if I put the primary and secondary clutch from Maverick turbo, can I leave the engine brake in the primary clutch? No harm to the belt? After all, in the original, the Maverick turbo has no engine brake in the primary.I am running turbo clutches on both my mav non turbo and my commander and have no problems with speed or belt life . I did have to get different springs for the clutches as I'm a bit on the picky side .
Thank you for the hint, I did not immediately guess what was being discussed due to the inaccuracy of the translation, I thought that we were talking about distance rings as in the secondary Stm!) And now, after reading thousands of pages on this forum and the Maverick forum, I realized that it was about the remote bushing, which is located on the gearbox shaft! Thank you again!Let me mention that there are two thicknesses of distance rings in the secondary to my understanding. To be sure, compare the part number for the distance ring in the secondary of a regular commander/maverick vs a turbo maverick. If the part numbers differ, order one for a turbo maverick.
I believe that to be the case and will align your turbo secondary with your standard primary.
I added the little springs and cups to have the low rpm engine braking . The turbo secondary don’t squeeze the belt as tight at idle speeds so it more easy to squeal the belt on steep grades at walking speedsTroy,tell me please, if I put the primary and secondary clutch from Maverick turbo, can I leave the engine brake in the primary clutch? No harm to the belt? After all, in the original, the Maverick turbo has no engine brake in the primary.
And I understand correctly that I need to replace the spring in the secondary QSC Turbo with a softer one, so that this mod would work in can-am commander?
I apologize if I write in English with errors!
you wrote that you need to modify the secondary turbo clutch in order to leave the brake on the primary.Or you can still put the primary and secondary clutch Maverick turbo and just add springs and tendrils for braking and problems with the belt when going down a steep hill will not be?I added the little springs and cups to have the low rpm engine braking . The turbo secondary don’t squeeze the belt as tight at idle speeds so it more easy to squeal the belt on steep grades at walking speeds
