The weight controls rpm (shiftout ) When the rollers hit the lump on the end of the weight you are at full shiftout (clutch wont close any further )
is that what the weights look like that are in your commander? The one that is groundI did some looking and found a extra weight that I made for my commander .
We do lots of custom weights on our mountain sleds
Top one is the modded weight
Bottom is stock![]()
I would think if you had stock weights with the bump still on then you would have the same problem as everyone else.My commander has weights with the bump knocked off so I could get full shift
Hi Troy,Your weights and spring
That's all and your good
There are two used ones on the mav forum
Bolt should be 155mm MAX and be grade 12.9 SHCS (hard to find hex heads in that grade.)I just got my turbo clutch inner, governor, and 12-14mm stepped washer in. Do you think that a 160mm bolt will be too long? That is all that I could find locally.
It is a 2015 maverick 1000r.
Also will I need to grind the lump off the end of the weights to get full shiftout?
Running 30" outback max tires if that makes any difference.
