41 - 47 of 47 Posts
Discussion Starter #41
just put the bike on jack stands, belt seems fine. 4wd noise seems to be grinding/clicking in gearbox. i made a video it is just up loading now, ill post it when its done. also took bolt back out of yoke. while testing it in 4wd the front shaft almost looked bent while spinning..
Wtih that much slop in the yoke it will look bent when rolling. It could be bent as well and if it is that would make it even worse .
Discussion Starter #43
did test with and without yoke bolt both times shaft seemed to be bent slightly while spinning.
Pull the actuator off the gearbox put it in 4wd by hand then turn the front wheel see if it still clicking or it’s actually locked .
I’m in the process putting my 14 back together after having a similar sound/issue. Found broken front right axle tip (pisspoor design) . Front diff disassembly required to remove axle tip and circlip. Kinda think that’s where ya should be looking. Good luck!
65280
41 - 47 of 47 Posts
