I think his thinking is a c breaker is resettable and fuses are not is his thought, if it's blowing that often something may be getting very hot?Why what is the reason for installing a circuit beaker??
OUCH!!!!You will need at least a 350 amp.![]()
That was my thought....yes.Why are you wanting a fuse or circuit breaker on a winch .
Just incase the winch wire gets pinched it will trip the breaker . ??
You can buy an in-line circuit breaker at your local Autozone for under $5. I highly recommend putting one on as you would rather have the circuit breaker trip and reset than to burn up your winch or battery. I just put a winch on my Commander this weekend and was wondering if it had a built-in circuit breaker on the factory wiring. So I'm guessing the answer is no, so I will be installing one on mine. I saw a neat trick where a guy put the circuit breaker in an outlet box to keep it from shorting out. I'll probably do that.Hey all,
I am considering putting a resettable circuit breaker on my winch. I have a viper 4K wide spool. Using the factory installed 8 gauge (I think) wire. What size breaker would be best?
