21 - 26 of 26 Posts
Discussion Starter #22
Start over.....
Eco/Sport Mode switch works fine and lights up on display as it should. Unplugged it and made sure connections lined up and were clean. Still have P0790 code and check engine scrolling accross display.
Havn't taken it down the road yet for a mile or 2 to see if it goes into limp mode or as with my old Polaris Ranger it sometimes needed driving to "reset" something after battery had been unplugged and such. More times than not the indicators would go out and things would be fine. Gonna try that this evening.
Discussion Starter #23
Update ....
Turns out.... when you forget to plug the Override switch back in after having the tunnel out... your check engine light comes on and you get a code:redface::redface: OOPS.
Installed sport low overuse with switch. My check engine light is on and is giving me the same code. Did you ever find the problem?
21 - 26 of 26 Posts
